Shear Key effectiveness
I am wanting to get some opinions on the use of shear keys to increase sliding resistance of retaining walls.
Does anyone have an opinion on shear key effectiveness.
RE: Shear Key effectiveness
One must allow in the design for a certain degree of movement of the wall into the passive soil in front of the key so that the resistance can be generated in this soil at the toe. Also I believe that the passive face must be protected from the effects of weathering and moisture absorbtion (especially in clays). Therefore, it is best to cover the passive key material with a part of the wall base slab. Also, good routing of the through-wall drainage away from the toe is essential in order to prevent swelling/softening of clay toes.
Andy Machon
Andy@machona.freeserve.co.uk
