pleated paper cartidge filter - active area
I have an Intex 2500 gpm pool pump with Intext type B pleated paper cartidge filters. Water flows from the OD of the plated filter to the ID.
I replace the filters when I notice a significant drop in the flow. When I look at the removed filter, I inevitably see that a lot of junk has accumulated all along the I.D. folds of the pleats, but nothing anywhere else. It seems like the bulk of the pleats do nothing except channel water, and all the filtering is done by the crease. Is that the way it's supposed to work?
RE: pleated paper cartidge filter - active area
Orenda
Hydrae
