cryogenic check valve with drilled hole
What is the point of drilling a 3/16” bleeding hole on the disk of 10" cryogenic check valve?
Fluid temperature -265°F.
Thanks in advance
Thanks in advance
RE: cryogenic check valve with drilled hole
Could you please explain in more detail?
In my understanding, the liquid through the hole will flash into gas, which serves as buffer between cryogenic temperature and ambient.
There maybe other reasons, but that is why I would put the hole in the disk.
