How would you model this? Bending a tapered tube
I've been away from SWx for a few years and I'm unsure what the best approach would be.
The part starts out as a straight tube. the outside is machined to a taper on both ends. The ends are then bent at about 45 deg, so that it ends up looking like sort of an open trapezoid, if you know what I mean.
I don't have the tubing function installed (as far as I know). I could do a sweep for the OD, and a loft for the ID and do a boolean subtract....but is there a better way?
RE: How would you model this? Bending a tapered tube
Sweep the OD using the Thin Feature option
Add a Chamfer at both ends
cheers
Or sweep a surface and thicken the surface to your wall thickness (if uniform).  Might combine a sweep with guide curves and a loft for the end bit where the ends are bent.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all.  And awe transcends reason.
