Seismic calculations
Where can I read about Seismic calculations?
In particular I am interested in calculating reactiong at base of the support skirt and how it is derived?
Thanks and regards,
s1111
Thanks and regards,
s1111
RE: Seismic calculations
API 650, Appendix E provides some good seismic information for tank designs. It's geared for tanks, but look at it and it may provide you what you need.
I understand that Manos has developed seismic design criteria and calcs that are superior to API, but I can't verify that.
Greg Lamberson, BS, MBA
Consultant - Upstream Energy
Website: www.oil-gas-consulting.com
http://www.fema.gov/hazard/earthquake/index.shtm
http://www.engr.psu.edu/ae/SteelStuff/seismic.htm
Big subject, check these.
WOuld it be possible for you to point out also where I could find IS-1893.
Thanks in advance.
s1111
Sorry, not only do I not know where to get it, I don't even know what it is!!
The IS-1893 is the Indian standard for seismic. Currently, IS-1893 (2002) is latest (it was last updated in 2002).
Thank you.
s1111
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
Want to post an image? Look at the FAQ's in forum559: SolidWorks 3D CAD products
Thank you very much for the information.
I also found IS-1893 like that. Its not quite surprising to find it so easily.
s1111
