Sketcher geometry in black instead of white......
I've had some issues with Catia lately and had to reset some of my CatSettings, and now I have another issue from that.
Anytime I draw in Sketcher, my geometry is black instead of the default white like it typically is. I have checked tools - options -sketcher and the default color of elements is set to white, so I'm not quite sure where else this needs to be set to get my geometry back to white again.
Thanks in advance for your help.
RE: Sketcher geometry in black instead of white......
But instead of changing the instance color to "automatic", I change the color to "no color"
(make sure you're in the Assembly workbench when you do this)
