NDT of rig equipments
Do any one know about Inspection and testing of rigs.
RE: NDT of rig equipments
0481
You'll need to be a little more specific - what types of rigs, what service and what type of inspections - fit for purpose, mechanical integrity, etc.
Greg Lamberson, BS, MBA
Consultant - Upstream Energy
Website: www.oil-gas-consulting.com
Thanks for reply
Rig is work over type romanian rig T50B
There is a lot you can inspect! Is it an old rig, which has been in for service and has been repaired? --> API 4G. I found the CAODC (Canadian Association of Drilling Contractors) guidelines very useful for the structural elements of work-over rigs. The main emphasis on the rig structure will be welding inspection. Checking a good sample of welds, requesting paint to be stripped from welds where you want to take a closer look, MPI, dye penetrant, etc. Beyond this, there are a lot of specialist areas to look at and really a specialist should do it. I recommend you read all the API's on drilling equipment. To get a fitness for purpose you will need at least 10 days on the job. A rig is an entire industrial plant in itself. You have electrical, pressure equipment, structure, liftings, OSHA, rotating and all that under heavy use conditions all there in one spot.
If you have specific questions, post them and we will answer.
O481
Do you have a photo of that rig? I assume it is a 50t , but I cannot find any details of the Romanian T50B on the web. It is for my own interest.
GL 431
Thanks for valuable information
I dont know how to post picture give me e-mail i will send u
