arc length dimension leader
Draw an ARC 181 degree and the arc length dimension leader line look good- radiating from the centre.
Draw an ARC 179 degree and the arc length dimension leader line look bad- horizontal to the end points.
Is it possible to maintain radial leader lines for all angles?
RE: arc length dimension leader
David
