Extracting information from Workbench simulation
I am new to workbench environment. I am using v 10.0 and have questions about how to get results information about a specific location.
For example: I need directional deformation data on only one face. I can plot it by selecting only that one face, but how can I dump the data into ascii?
Also, is there a way to extract all the nodes/elements information of the model from Workbench so that it can be imported into Classic?
Thanks in advance.
Thanks in advance.
RE: Extracting information from Workbench simulation
Now that you have the database file an *.rst or *.rth is automatically created when solving in WB. This file should be present in the solver working directory. You should be all set at this point.
If you have trouble post and I'll try to be of more help when I have Ansys up in front of me.
Good luck.
while Stringmaker's suggestions are valid on general terms, for the specific problem you have asked it is useless to go to Classical:
- request a Solution Item such as "Deformation -> Directional" where the scope is limited to the only face of interest
- request "Calculate results" (warning: not "solve", of course...)
- right-click on the solution item, and choose "Export". It will send it automatically to Excel. Warning: in Excel, it SEEMS the format is "xls" but it is NOT: it's a formatted text format; so, when you want to save it, choose the proper "xls" format.
If, in the Options, you choose to "Save nodes locations" together with the results, the Excel columns will be:
- node number
- X coord
- Y coord
- Z coord
- result value
You can not export several results types at the same time: you've got to send them to separate Excels, then copy-paste.
Warning: in v.11, the data saving procedure is completely different, since the "Export" option has disappeared: every result is presented as tabular data directly into the "Tabular Data" panel (which can auto-hide, so activate it if you can't see it...), from which you can copy-paste as if you already were in Excel ("a bit" more limited, but it works anyway... And allows you to partial selections, not bad).
