Sodium Beta Alumina Solid Electrolyte (need sources)
I'm going to try my hand at building my own Sodium/Nickel Thermal Battery packs.
Only problem I'm running into is a source for Na-??-alumina and/or it's precursors. I want it in powder or paste/slurry form so I can dictate it's final shape and sinter it myself.
Does anyone have any info on sources of Na-??-alumina (ready for final processing), or info/sources for the precursors. (?-alumina, Aluminum Oxide, Sodium Oxide)
I've found numerous sources for Aluminum Oxide of questionable grade, 1 or 2 sources for ?-alumina, but no sources for Sodium Oxide (NaO2) or Na-??-alumina.
I will incorporate as a one-man-research-company if need be but I'd rather find sources that will sell to an individual in small bulk quantities. I only need a few dozen Kilos of the final product.
