Discharge flow calculation
I am looking to calculate the discharge flow from a 6" outlet pipe (pvc). I am using manning's, but am not sure I have taken into account the wetted perimeter correctly (depth of flow).  Does anyone have an excel program that may work?  Thank you.
RE: Discharge flow calculation
If it is gravity flow you, want to determine, there are charts that are more readily available.  Typically they denote the flows for different grades and how full the pipe is.  They are based upon Manning.  Check one of those out.
Yes, gravity flow.  Thanks, I will look for a published chart.  If you have a suggestion on where to find one that shows varying depths of flow, that would be appreciated.
If you cannot find the diagram previously mentioned, the fifth Edition of the "Handbook of Hydraulics" by King & Brater (1963), on page 7-3 has diagrams for specific channel shapes, and the wetted perimeter formulas for each.
Been using it for years.  No worries.
Mike McCann
McCann Engineering
Forgot to mention that the tables you need to go alongwith the formulas are on pages 7-25 through 7-60.  Hope you can find the book.  It's very helpful.
Mike McCann
McCann Engineering
I use Frankel's Facility Piping Systems Handbook.
I tried to google to find a simple pdf and could not find the tables.  I found equations and nomographs which could also be used.
I do find it a little disconcerting that as qulaifiied engineers/technicians we cannot calculate the area and perimiter of a segment of a cricle and have to resort to tables and graphs published in handbooks.
I agree with that somewhat.  But why reinvent the wheel.
I could calculate the wetted perimeter and the density of the water to get the actual volume of the water I want to calculate the flow for.  I could solve Bernoulli's equation and calculate the appropriate friction factor for the type of pipe and get the flow to 3 significant figures.  And that might take me up to an hour to do it.
Or I can pull out my book where other engineers have done these calculations and have published the table for other engineers to use and it takes me about 5 minutes to come up with the answer.
What I find disconcerting is that sometimes engineers do not know the calculations behind the tables they are using and get a very wrong answer and do not have the common sense to know that their answer is wrong.
BlueR,
I have written VBA functions for MS Excel
to calculate partial flow in circular pipes to find depth vs. flow/froude number/velocity etc.; or to calculate hydraulic radius etc.
let me know if you want to use it.
I made my own spreadsheet. It tells me the velocity and q for any depth,any slope any pipe, as long as I have a decent 'n' value. It also gives me a vol. of dirt in a partially filled pipe. So I know what volume has to be removed. All you need is a few simple area formulae and a little imagination. Of course 2nd year high school algebra helps. Pedarrin2's comment is also very true.
Richard A. Cornelius, P.E.
WWW.amlinereast.com
elev8848, I just came across this thread, and am trying to do what it sounds like you have already done in excel. Mind sharing?
JFergus,
Sorry for late reply. Didn't follow the thread for a while. I will respond from home in the evening.
BlueR wrote: "I am looking to calculate the discharge flow from a 6" outlet pipe (pvc). I am using manning's, but am not sure I have taken into account the wetted perimeter correctly (depth of flow).  Does anyone have an excel program that may work?  Thank you."
Available free software applications for this include CDSS, HEC-RAS, HLW, HY8, HydroCulv, SWMM, and WSPro. I suggest HLW for quick calculations and SWMM for partially filled conduits. Download links for these are at "http://hhwq.blogspot.com". There are several hydraulic spreadsheets at the HHWQ site as well. The "Bruce Hunt PhD: Software and PDF Texts" has links to a fluid mechanics text which will provide information on wetted perimeter.
As a side note, you might be interested in using OpenOffice (from Sun Microsystems) as an alternative to Microsoft Office applications (such as Excel). I highly recommend OpenOffice. It is completely free and open source. You might also be interested in Gnumeric, another spreadsheet software application that is also free and open source. I don't use it, but it appears highly recommended. Microsoft Office files (such as Excel) are supported by both OpenOffice and Gnumeric.
tsgrue: site engineering, stormwater
management, landscape design, ecosystem
rehabilitation, mathematical simulation
'JFergus: here it is! Not the best algorithm but works!
'It was a learning process
'VBA FUNCTIONS FOR PARTIAL FLOW IN CIRCULAR PIPE
Option Explicit
Global Const Pi = 3.141592654
Function radFt(diaFt As Double)
    'radius in Feet
    radFt = diaFt / 2
End Function
Function circm(diaFt As Double)
    'circumference
    circm = Pi * diaFt
End Function
Function area(diaFt As Double)
    'Cross sectional area
    area = Pi * diaFt * diaFt / 4
End Function
Function theta(diaFt As Double, Y As Double)
    'theta radians = half of angle at the center
    'y = partial fill depth
    Dim R As Double
    R = radFt(diaFt)
    'Four possibilities
    'case 1: y<R
    If Y < R Then
    theta = Atn((diaFt * Y - Y * Y) ^ (0.5) / (R - Y))
    Else
       'case 2: y=R
        If Y = R Then
            theta = Pi / 2
        Else
           'case 3: 2R>y>R
           If Y > R And Y < diaFt Then
               theta = Pi + Atn((diaFt * Y - Y * Y) ^ (0.5) / (R - Y))
            Else
                'case 4: y>=2R
                theta = Pi
            End If
        End If
    End If
End Function
Function wetP(diaFt As Double, Y As Double)
    'Wetted Perimeter
    wetP = theta(diaFt, Y) * diaFt
End Function
Private Function tArea(diaFt As Double)
    'cross sectional area
    'also defined earlier as area()
    tArea = Pi * diaFt * diaFt / 4
End Function
Function flowArea(diaFt As Double, Y As Double)
    'Partial Flow Area
    Dim R As Double
        R = radFt(diaFt)
    Dim sect As Double 'sectoral area
    Dim tri As Double  'triangular area
    sect = theta(diaFt, Y) * tArea(diaFt) / (Pi)
    tri = Abs(R - Y) * (Abs(Y * diaFt - Y * Y)) ^ 0.5
    'Four conditions
    If Y < R Then
        flowArea = sect - tri
    Else
        If Y = R Then
            flowArea = sect
        Else
                flowArea = sect + tri
            Else
                'If y >= diaFt Then flowArea = sect
                flowArea = sect
            End If
        End If
    End If
End Function
Function hydR(diaFt As Double, Y As Double)
    'Hydraulic Radius
    If Y = 0 Then
        hydR = 0
    Else
        hydR = flowArea(diaFt, Y) / wetP(diaFt, Y)
    End If
End Function
Function fullQ(diaFt As Double, n As Double, s As Double)
    'Full bore flow using Manning's Eqn
    'Unit cfs
    fullQ = 1.486 / n * tArea(diaFt) * (diaFt / 4) ^ (2 / 3) * s ^ 0.5
End Function
Function partialQ(diaFt As Double, Y As Double, n As Double, s As Double)
    'Partially filled flows as open channel
    'Manning's Eqn
    'Unit cfs
    partialQ = 1.486 / n * flowArea(diaFt, Y) * hydR(diaFt, Y) ^ (2 / 3) * s ^ 0.5
End Function
Function topWid(diaFt As Double, Y As Double)
    'Top free surface width
    Dim R As Double
        R = radFt(diaFt)
    'Four cases
    If Y <= R Then
        topWid = 2 * (R ^ 2 - (R - Y) ^ 2) ^ 0.5
    Else
            topWid = 2 * (Y * diaFt - Y * Y) ^ 0.5
        Else
            'If y > diaFt Then topWid = 0
            topWid = 0
        End If
    End If
End Function
Function vel(diaFt As Double, Y As Double, n As Double, s As Double)
    'Velocity for a particular depth for partial Flow
    If Y = 0 Then
        vel = 0
    Else
        vel = partialQ(diaFt, Y, n, s) / flowArea(diaFt, Y)
    End If
End Function
Function Froude(diaFt As Double, Y As Double, n As Double, s As Double)
    'Froude's Number for a given depth of flow
    'Froude=partialQ^2*topWid/32.2/flowArea^3
    Dim Q As Double
    Dim T As Double
    Dim a As Double
    Q = partialQ(diaFt, Y, n, s)    'Partial Flow
    T = topWid(diaFt, Y)
    a = area(diaFt)
    Froude = Q ^ 2 * T / a ^ 3 / 32.2
End Function
Function yNormal(diaFt As Double, n As Double, s As Double, givenQ As Double)
    'How to converge on the answer fast?
    'Normal Depth for a given flow Q
    'Unit is Feet
    Dim Y As Double 'Trial y
    Dim calcQ As Double 'calculated Q
    Dim loopCount As Double   'erase later
    Dim errorQ As Double
        errorQ = 0.001
    Dim yMax As Double
    Dim yMin As Double
    yMax = diaFt    'initial assumption
    yMin = 0        'initial assumption
    Y = (yMax + yMin) / 2
    'Normal depth has no meaning for pressurzied pipe
    'Pressurized if givenQ > capacity
    If givenQ > fullQ(diaFt, n, s) Then
        Y = diaFt
        'MsgBox "Pressurized Flow, exceeded open channel flow capacity" _
        Else
        Do While (Abs(partialQ(diaFt, Y, n, s) - givenQ) > errorQ)
            loopCount = loopCount + 1
            calcQ = partialQ(diaFt, Y, n, s)
            'Three Conditions
            '(calcQ>givenQ) or (calcQ<givenQ) or both equal
            If calcQ = givenQ Then
                'go out of loop
            Else
                If (calcQ > givenQ) Then
                    'y solution is smaller than y assumed
                    yMax = Y
                    yMin = yMin
                Else
                    'y solution is greater than y assumed
                    yMax = yMax
                    yMin = Y
                End If
            End If
        Loop
    End If
    'MsgBox "loopCount for yNormal = " & loopCount
    yNormal = Y 'Return result
End Function
Function poly(diaFt As Double, anyQ As Double, assumedY As Double)
    poly = flowArea(diaFt, assumedY) ^ 3 / topWid(diaFt, assumedY) - anyQ ^ 2 / 32.2
End Function
Function polySolve(P As Double, diaFt As Double, givenQ As Double)
    'solve equation poly for P
    ' poly(y)=P: find y
    Dim Y As Double
    Dim yMax As Double
    Dim yMin As Double
    Dim error As Double
        'Initialize
        error = 0.00001
        yMax = diaFt
        yMin = 0
    If loopCount > 5000 Then
        polySolve = 999         'flagging error
    Else
        Do While (Abs(poly(diaFt, givenQ, Y)) > error)
            If poly(diaFt, givenQ, Y) > 0 Then
                yMax = Y
            Else
                yMin = Y
            End If
        Loop
    End If
   ' MsgBox "loop count = " & loopCount
    polySolve = Y
End Function
Function Froude1(diaFt As Double, yTest As Double, knownQ As Double)
    'Used for yc calculation
    'Froude1: Froude Number for given dia, known Q but test depth
    'only to be called by function to calculate the critical depth
    Froude1 = (knownQ ^ 2 * topWid(diaFt, yTest) / flowArea(diaFt, yTest) ^ 3 / 32.2) ^ (0.5)
End Function
Public Function yc(diaFt As Double, knownQ As Double)
'better use this to calc critical depth
Dim max As Double
Dim min As Double
Dim yTry As Double
Dim loopCount As Integer
max = diaFt
min = 0
yTry = (max + min) / 2
    If knownQ <= 0 Then
        yc = 0
        Else
            Do While (Abs(Froude1(diaFt, yTry, knownQ) - 1) > 0.000001) And loopCount < 100
                If Froude1(diaFt, yTry, knownQ) < 1 Then
                    max = yTry
                Else
                    min = yTry
                End If
            Loop
            'MsgBox "loop count = " & loopCount
            yc = yTry
    End If
End Function
Sub examples()
    Dim msg As String
    'example 1
    msg = "Full Flow example 1 = " & fullQ(1.5, 0.013, 0.027) & " cfs"
        MsgBox msg
    msg = "Partial Flow example 2 = " & partialQ(1.5, 0.5, 0.013, 0.027) & " cfs"
        MsgBox msg
    msg = "Froude# example 3 = " & Froude(1.5, 0.6, 0.013, 0.035)
        MsgBox msg
    msg = "Velocity example 4 = " & vel(1.5, 0.5, 0.013, 0.027) & " ft/sec"
        MsgBox msg
End Sub
For interested ones:
To use the VBA, copy the entire code into a module. The last subroutine is an example. The functions are more useful when used in a spreadsheet.
Verify few results with tables or calculations.
