Design Table and Equations
Hey Everyone,
I have a part where many things patterns, cuts etc. are linked through equations, so that you only have to update one number and it will update many features, to a different extent and while referencing sizes/dimensions contained within the part as well.
However it is a little slow and also impermanent to change the 5 or so driving equations by hand and saving each configuration. Is there a way to reference the equation variable that I want to change from the table? Any ideas of what that callout would be? For a more specific example I have one equation that is "height"=20 (or whatever). Ideally I want to make the design table column height, and set different configurations at different heights from that one number, despite the number being in a complicated relationship to the part.
Any help would be appreciated,
Xander
Xander
RE: Design Table and Equations
Have you investigated the use of DriveWorks or DriveWorks Express?
Also I have not used drive works or drive works express, but I will look into that, although this seems like something that solidworks must be able to do, and that would be much simpler (for all the parts I handle) to do in solidworks.
Xander
This is a limitation. You cannot transfer equation variables into a design table. What you can do is input all your information and do all your math in the design table. And as CBL you could look into DriveWorksXpress.
cheers,
Thank you again,
Xander
Just one way to get around the variable / design table limitations
Jason
SolidWorks 2007 SP4.0 on WinXP SP2
