XY coordinates from a polyline
Is there a easy way to extract the X,Y, coordinates from a polyline? Right now, i have to convert it into a dxf, and then import it into another program to get the X, Y. I was wondering if anyone has a quicker way to achieve this outcome? Any help is much appreciated.
RE: XY coordinates from a polyline
http://dotsoft.com/freestuff.htm
____________________
Acad2006, Terramodel
Thanks!
OK here's the requested routine, it took just 2 little edits to have it use current UCS coordinates. Enjoy, & report any problems :)
CODE
; (Export LWPOLYLINE Vertices & Points to File)
; Copyright (C) 2000 DotSoft, All Rights Reserved
; Website: http://www.dotsoft.com
; DISCLAIMER: DotSoft Disclaims any and all liability for any damages
; arising out of the use or operation, or inability to use the software.
; FURTHERMORE, User agrees to hold DotSoft harmless from such claims.
; DotSoft makes no warranty, either expressed or implied, as to the
; fitness of this product for a particular purpose. All materials are
; to be considered ‘as-is’, and use of this software should be
; considered as AT YOUR OWN RISK.
;;Revised 8/23/07 CAB to report coordinates in current UCS
(defun c:ptexport ()
(setq sset (ssget '((-4 . "<OR")(0 . "POINT")
(0 . "LWPOLYLINE")(-4 . "OR>"))))
(if sset
(progn
(setq itm 0 num (sslength sset))
(setq fn (getfiled "Point Export File" "" "txt" 1))
(if (/= fn nil)
(progn
(setq fh (open fn "w"))
(while (< itm num)
(setq hnd (ssname sset itm))
(setq ent (entget hnd))
(setq obj (cdr (assoc 0 ent)))
(cond
((= obj "POINT")
(setq pnt (cdr (assoc 10 ent)))
(setq pnt (trans pnt 0 1));;**CAB
(princ (strcat (rtos (car pnt) 2 8) ","
(rtos (cadr pnt) 2 8) ","
(rtos (caddr pnt) 2 8)) fh)
(princ "\n" fh)
((= obj "LWPOLYLINE")
(if (= (cdr (assoc 38 ent)) nil)
(setq elv 0.0)
(setq elv (cdr (assoc 38 ent)))
(foreach rec ent
(if (= (car rec) 10)
(progn
(setq pnt (cdr rec))
(rtos elv 2 8)) fh)
(princ "\n" fh)
(t nil)
(setq itm (1+ itm))
(close fh)
(princ)
(princ "\nPoint Export loaded, type PTEXPORT to run.")
(princ)
Thanks! This routine will help with my slope stability analyses.
