Shaft materials for Delrin 500 AL bushing
Hi, I'm picking up a design from another engineer. He selected Delrin 500 AL as a bushing material and a medium carbon steel, hardened and then zinc plated for corrosion resistance. Of course, the zinc plating is abrading.
I was thinking of switching to a 304 SS for the shaft material but thought the people here might have better suggestions.
Anyone have a better choice of shaft materials for running a Delrin 500 AL bushing on?
RE: Shaft materials for Delrin 500 AL bushing
Polyester is good against acids but not alkalis
PEs are better against both, but are soft and have lower melting temperatures.
It is always a compromise between the balance of various properties.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Can you comeback with a little more information on what you are trying to do with information on speeds and loads?
