Defalt printer in autocad 2005 ?
Can anyone help me with setting a default printer in autocad 2005?  I only use autocad to print out drawings I get from customers so when I open a file to plot the 'printer/plotter' heading says none.  I select a printer, print the file, and then close that file.  When I open the next file I want to print the 'Printer/plotter' says none again, how can I make this stick to a printer rather than none?
RE: Defalt printer in autocad 2005 ?
Hi mrkoto,
You can set this option in the AutoCAD options dialog box.
HTH
Todd
As Tcarpenter1 says, there is a steeing in the options to set a default printer, but It has NEVER worked for me.  I created a LISP reactor to verify the printer to be used is my correct one, and if not it will set it to be the correct printer. (AutoCAD really should be able to do this on it own, but like I said It has never work properly for me).
In addition to fixing the printer problem. this lisp will also automatically put dimensions you draw on the DIMENSIONS layer, Text of the TEXT layer, hatches on the HATCH layer.  you can modify it functionallity to suit your need and system.
I hope this helps!
CODE
; Command Reactors to set entities on the appropiate layer
; without user intervention.
; Programmed by: Kevin Petursson
; Date: October 6, 2006
; Revisions: 1 - October 16, 2006.  Added 'defun setLayerCurrent' to
;              check for layer prior to setting layer. If the layer
;              does not exist, it will be created.
;              Added Printer Checking routines
;            2 - March 20, 2007. Added REVCLOUD to the automatic Text Layer
; Big thanks to Lee Ambrosius and his article in July 2006
; AUGIWorld magazine on Command Reactors
; Load the Visual LISP library
(vl-load-com)
; Check to see if our custom command reactors
; have been loaded into the current drawing
(if (= hyp-rctCmds nil)
  ; Add the command reactors and the custom callbacks
  (setq hyp-rctCmds (vlr-command-reactor nil '((:vlr-commandCancelled . hyp-cmdAbort)
                           (:vlr-commandEnded . hyp-cmdAbort)
                           (:vlr-commandWillStart . hyp-cmdStart)
; Callback used when the user presses ECSape
; or when the command ends by itself or due to
; a problem
(defun hyp-cmdAbort (param1 param2)
  ; Check to see if our global variable has a value
  ; if it does the set the current layer
  (if (and (/= hyp-gClayer nil)(/= (strcase (getvar "clayer")) (strcase hyp-gClayer)))
    (setvar "clayer" hyp-gClayer)
  ; Clear the global variable
  (setq hyp-gClayer nil)
; Callbackused when a command is started
(defun hyp-cmdStart (param1 param2 / currentlayer)
  ; Store the current layer in a global variable
  (setq hyp-gClayer (getvar "clayer"))
  ;check to see what command has been started, the
  ; command name is stored in the param2 variable
  (cond
    ; If either the QDIM command
    ; is active the set the current layer to Dimensions
    ( (or
    (= (car param2) "DIMALIGNED")
    (= (car param2) "DIMANGULAR")
    (= (car param2) "DIMBASELINE")
    (= (car param2) "DIMCONTINUE")
    (= (car param2) "DIMDIAMETER")
    (= (car param2) "DIMLINEAR")
    (= (car param2) "DIMORDINATE")
    (= (car param2) "DIMRADIUS")
    (= (car param2) "QDIM")
      (setLayerCurrent "Dimensions")
    ; If either the HATCH, BHATCH or GRADIENT command
    ; is active the set the current layer to Hatching
    ( (or
    (= (car param2) "HATCH")
    (= (car param2) "BHATCH")
    (= (car param2) "GRADIENT")
      (setLayerCurrent "Hatching")
    ; If either the Viewport command
    ; is active the set the current layer to Viewport
    ( (or
    (= (car param2) "VPORTS")
    (= (car param2) "-VPORTS")
      (setLayerCurrent "Viewport")
    ); If either the MTEXT, DTEXT, QLEADER, LEADER, Revision Cloud command
    ; is active the set the current layer to Text
    ( (or
    (= (car param2) "TTEXT")
    (= (car param2) "DTEXT")
    (= (car param2) "MTEXT")
    (= (car param2) "LEADER")
    (= (car param2) "QLEADER")
    (= (car param2) "REVCLOUD")
      (setLayerCurrent "Text")
    ; If either the LAYER command
    ; is active the clear global variable for the current layer
    ( (or
    (= (car param2) "LAYER")
    (= (car param2) "-LAYER")
      (setq hyp-gClayer nil);Clear the global variable to allow the layer command to change the current layer
    ; If either the Plot command
    ( (or
    (= (car param2) "PLOT")
    (= (car param2) "-PLOT")
      (progn
    (SwitchDefaultPrinter);confim the printer being asked for is a current device
;Set the current layer.  If the layer specified does not exist, it will be created.
;Thank to Lee Ambrosius for his help with this code.
(defun setLayerCurrent (layname / acadObj docObj layColl layObj colour)
  (if (= (tblobjname "layer" layname) nil)
    (progn
      (setq acadObj (vlax-get-acad-object))
      (setq docObj (vla-get-activedocument acadObj))
      (setq layColl (vla-get-layers docObj))
      (setq layObj (vla-add layColl layname))
      (setq colour 0)
      (if (= layname "Dimensions")(setq colour 4))
      (if (= layname "Hatching")(setq colour 8))
      (if (= layname "Viewport")(setq colour 9))
      (if (= layname "Text")(setq colour 4))
      (vla-put-color layObj colour)
      (setvar "clayer" layname)
; Check if the plotter last saved with the file is in a list of
; current devices.  If it is not, change  the plot device to a current
; device, If it is, leave things alone.
(defun SwitchDefaultPrinter (/ Default ad OldPlotDevicee PlotDevices NonCurrentDevice)
  (setq Default "\\\\bdn01ps001\\drafting_lj8000");Set default printer
  ;create list of current plot devices
  (setq PlotDevices (list "Bluebeam PDF Printer"
        "\\\\bdn01ps001\\black_laser"
        "\\\\bdn01ps001\\ccc_colorlaser"
        "\\\\bdn01ps001\\ccc_lj8150"
        "\\\\bdn01ps001\\color_laser"
        "\\\\bdn01ps001\\drafting_plotter"
        "Black_Laser_D_to_B_Batch.pc3"
        "Color_Laser_A_to_A.pc3"
        "Color_Laser_A_to_B.pc3"
        "Color_Laser_B_to_B.pc3"
        "Color_Laser_C_to_B.pc3"
        "Color_Laser_D_to_B.pc3"
        "Color_Laser_D_to_B_PID_Batch.pc3"
        "Color_Laser_D_to_D_PID_Batch.pc3"
        "Drafting_Plotter.pc3"
        "Drafting_Plotter_Batch.pc3"
        "Drafting_Plotter_BW.pc3"
        "Drafting_Plotter_D_to_D_BW_Batch.pc3"
  (setq ad (vla-get-activedocument (vlax-get-acad-object)));Set variable to hold reference to the active document
  (setq OldPlotDevice (GetActivePlotDevice ad));Set variable to hold reference to current plot device
  ;comapre the old plot device to a list of current devices
  (if (= nil (vl-position OldPlotDevice PlotDevices))
    (setq NonCurrentDevice 0);Device not found in list
    (setq NonCurrentDevice 1);Device found in list
  (if (= 0 NonCurrentDevice);if the current device is not in the current list of active devices.
    (progn
      (vla-put-ConfigName (vla-get-ActiveLayout ad) Default);Change the plotter name to be used by the active layout
      (setq PrinterSwitched 1)
    ;other wise leave it alone.
  (if (= nil (vl-position (vlax-get-property (vla-get-ActiveLayout ad) "StyleSheet") (GetPlotStyleTableNames ad)));check the list of CTB files for the current requested CTB
    (vlax-put-property (vla-get-ActiveLayout ad) "StyleSheet" "Black_Laser.ctb");Current CTB Not found, set CTB file to "Black_Laser.ctb"
    ;Curerent CTB found, don't worry about it
  (if (= 1 PrinterSwitched)
    (progn
      (if (/= nil (vl-position "11x17" (GetCanonicalMediaNames ad)));check list of paper sizes for 11X17
        (vlax-put-property (vla-get-ActiveLayout ad) "CanonicalMediaName" "11x17");11X17 found in the list of paper sizes, set paper size to 11x17
        ;11x17 is not in the list, don't worry about it
      (vlax-put-property (vla-get-ActiveLayout ad) "CenterPlot" -1);Set to center the plot on the paper
      (vlax-put-property (vla-get-ActiveLayout ad) "StandardScale" 0);Set to "Scale to Fit
      (vlax-put-property (vla-get-ActiveLayout ad) "PlotType" 1);Set to plot extents
      (vlax-put-property (vla-get-ActiveLayout ad) "PlotRotation" 1);Set to print Landscape
  (princ)
(defun GetActivePlotDevice (ad)
  (vla-get-ConfigName
    (vla-get-ActiveLayout ad))
(defun GetCanonicalMediaNames (ad)
  (vla-RefreshPlotDeviceInfo
    (vla-get-activelayout ad))
  (vlax-safearray->list
    (vlax-variant-value
      (vla-GetCanonicalMediaNames
        (vla-item (vla-get-layouts ad) "Model"))))
(defun GetPlotStyleTableNames (ad)
    (vlax-variant-value
      (vla-getplotstyletablenames
