Typesetting ChE documents with LaTeX
Dear Eng-Tip-pers,
Has anyone ever published a ChE Technical document using the typesetting program LaTeX? If so, could you please give me some recommendations of packages or tips to use, specially, for chemical engineering?
TIA, dogtop
TIA, dogtop
RE: Typesetting ChE documents with LaTeX
I have often used LaTex, and simply love the quality and distinct look. I only have experience with MikTex and, like others, it has a fairly steep learning curve.
Thanks for your response. I'd like to use LaTeX to draw PFDs and P&IDs in reports to clients rather than for publishing papers. Maybe I will try to write a ChE package.
Thanks, dogtop
The package I use nowadays for combining Latex formulas and graphics, is called IPE. Excellent quality, "easy" to use and you can have multiple sheets.
Inkscape may suit you better, and support Latex through extensions.
Could you give more details about IPE? What does IPE stands for? Is there a website for IPE?
TIA,
dogtop
Website for Ipe is:
http://tclab.kaist.ac.kr/ipe/
Website for Inkscape is:
http://www.inkscape.org/
Thanks a lot.
dogtop
