Autocad 2d- Aligning text to object
I prepare structural floor plans for buildings within an engineering consultancy - and modern buildings being what they are tend not to have a square wall on them. So I am constantly having to insert text then use the rotate command to approximatley 'align' it with the approprate lines on the drawing.
Does anyone know of an available lisp (or other) which would allow me to quickly and easily align text with a specific object (usually a line).
DW
DW
RE: Autocad 2d- Aligning text to object
CODE
; local functions
getSegment get-opp-ang undobegin undoend
; local variables
ent txt_ent obj txt_obj obj_typ ang ans
;;; FUNCTION
;;; rotates the user selected (M)TEXT to the user selected
;;; entity. valid entites are light weight plines, lines
;;; and (m)text. you are given the chance to rotate the
;;; by 180 degrees after intial rotation.
;;; ARGUMENTS
;;; none
;;; USAGE
;;; enter RRT on the comand line
;;; PLATFORMS
;;; 2000+
;;; AUTHOR
;;; Copyright© 2004 Mark S. Thomas
;;; mark_AT_theswamp.org
;;; VERSION
;;; 1.0 Tue Dec 07, 2004
;;; 1.1 Tue Dec 21, 2004 ; added ARC types
;;; 1.1a Tue Dec 21, 2004 ; reversed the pick order
;;; TODO:
;;; handle text that has 'fit' justification
;;; add more entites for angle extraction
;;; more testing
(vl-load-com)
;; credit Stig Madsen
;; refer to thread titled "relaxed-curves" under the "Teach Me"
;; section of TheSwamp at www.theswamp.org/phpBB2/
(defun getSegment (obj pt / cpt eParam stParam)
(cond ((setq cpt (vlax-curve-getClosestPointTo obj pt))
(setq eParam (fix (vlax-curve-getEndParam obj)))
(if (= eParam (setq stParam (fix (vlax-curve-getParamAtPoint obj cpt))))
(setq stParam (1- stParam))
(setq eParam (1+ stParam))
(list eParam (vlax-curve-getPointAtParam obj stParam)
(vlax-curve-getPointAtParam obj eParam))
;; undo functions
(defun undobegin ()
(vla-EndUndoMark
(vlax-get-property
(vlax-get-acad-object)
'ActiveDocument
(vla-StartUndoMark
(vlax-get-property
'ActiveDocument
(defun undoend ()
(vla-EndUndoMark
(vlax-get-property
'ActiveDocument
;; returns the oppsite of an angle define in radians
(defun get-opp-ang (ang)
(cond ((< ang pi)(+ ang pi))
((> ang pi)(- ang pi))
((equal ang pi) 0.0)
((equal ang 0.0) pi)
;; ================= body of main function starts here ======================
;; ----------- Get the Text to Align -----------------
(cond
((setq txt_ent (car (entsel "\nSelect text to align")))
(setq txt_obj (vlax-ename->vla-object txt_ent)
obj_typ (vlax-get-property txt_obj 'ObjectName)
(cond
((or (= obj_typ "AcDbMText") (= obj_typ "AcDbText")))
(T
(setq txt_ent nil)
(alert "I only know how to align (M)TEXT, sorry! "))
;; ----------- Get the Object to Align To -----------------
(cond
((and txt_ent
(setq ent (entsel "\nSelect entity for alignment: ")))
(setq obj (vlax-ename->vla-object (car ent))
obj_typ (vlax-get-property obj 'ObjectName)
(cond
((= obj_typ "AcDbPolyline")
(if (setq pt_lst (getSegment obj (last ent)))
(setq ang (angle (cadr pt_lst)(caddr pt_lst)))
((= obj_typ "AcDbLine")
(setq ang (vlax-get-property obj 'Angle))
((= obj_typ "AcDbText")
(setq ang (vlax-get-property obj 'Rotation))
((= obj_typ "AcDbMText")
((= obj_typ "AcDbArc")
(setq ang (angle
(vlax-safearray->list
(vlax-variant-value
(vla-get-StartPoint obj)))
(vlax-variant-value
(vla-get-EndPoint obj)))
(T (alert "That's not an entity I deal with"))
;; ----------- Align the Text -----------------
(cond
((null ang)) ; do nothing
((null txt_ent)) ; do nothing
(T
(undobegin)
(vlax-put-property txt_obj 'Rotation ang)
(setq ans (getstring "\nRotate 180 [Y/N]<N>: "))
(if (= (strcase ans) "Y")
(vlax-put-property txt_obj 'Rotation (get-opp-ang ang))
(vlax-release-object txt_obj)
(undoend)
(princ)
____________________
Acad2006, Terramodel
Thanks for that, Its just what I was looking for.
DW
