Max pressure fro 600#?
For ASME piping standards, what is the max pressure of a 600# line at 400F?
Thanks for saving me some time.
Tom
Tom
RE: Max pressure fro 600#?
Well, it depends on what material...
Please refer to ASME B16.5
See thread292-159508: Pipe vs Flange MAWP
thread177-172682: ANSI RAting of Flanges
The material groups are among the key issues. The absolute highest is 1500 psig at 100 degree F based upon material group 1.2. I have never seen this scenario.
The highest that I have seen is 1480 at 100 degree F based upon material group 1.1. As an instrument engineer I frequently have type 316 stainless steel flanges connected to the piping system. Material group 2.2 drops the maximum to 1440 at 100 degree F. However the piping systems rarely operate at the optimum temperature. I have noted 100 degree F where the published range is -20 to 100 degree F. Typically a low temperature piping specification covers up to 300 degree F. This drops the maximump pressure to 1120 psig due to my type 316 stainless steel flange. If I were to accept type 304 then the pressure at 300 degree drops to 1075 psig.
And I plan to use an existing Coriolis Meter with Hastelloy C-276 flanges. That means that I must look up the ASTM or ASME designation for Hastelloy C-276 then check to determine which material group table applies.
I though that this was supposed to be an easy answer, didn't you?
