Notes on datasheets
Notes on datasheets
Is there a way to extend the notes section on the bottom of a datasheet. When I usually try to put more than 3 lines of notes, it will let me enter that, but will only save 2 lines. Anything more than that is not saved and there is a limit of how many charachters can be entered in the notes section. Can this be changed?
RE: Notes on datasheets
On the note tab/sheet you will find the three rows you type in the datasheet.
Cheers
Carlo
CS Webservice-Online
http://www.cs-webservice.nl
