Transformation Feature
How can I move a solid using an axis as a start point and other axis created as the target? Basically, what is the equivalent of Transform/ Create/ Move from Catia V4 in CATIA V5?
Thank you.
Thank you.
RE: Transformation Feature
-- Jay
http
Please note: the "add position" option is not an axis transformation. It just adds a local reference. However, it stil requires multiple independent transformations, which rather defeats the purpose of axis to axis.
I'm at a loss to understand why there is no axis transformation for solid bodies. There are so many different design methods, and not every one ends up in production. I have a design that is being done in V5, and will be converted to V4. (because it's so much faster to design this one in V5) Therefore, a little "hacking and slashing" is tolerable.
Catia Design|Catia Design News|Catia V5 blog
· · CATIA - Part Design 1 (PD1)
· · Integration of transformation axis-to-axis and affinity features in Part Design - These two transformation features, available in Part Design, complete the set of transformations applicable to solid objects
can't remember if this is R18 or R19, but "axis-axis" is coming for part design workbench
