connection to brick
connection to brick
I need to find a fastener that can go intp a hollow brick and withstand about 400 lbs. of tension. I looked at Hilti anchors and what they have I can't use because I have another fastener about 3" away. If I have to space the fasteners further I will but I would rather not.
RE: connection to brick
There are plenty of other anchors that could be used including through bolts with a metal backing plate.
Spacing requirements generally result in reduced capacities for closely spaced anchors.
Where fire is not a concern, and sometimes even if it is, adhesive anchors may be a solution. Look then for the Adhesive Anchors design Manual of Powers as a pdf document.
