Retrofitting an old Powell 480V MCC starter.
We have an old (circa 1961) Powell P2000 480V MCC that I need 2 size 5 starters for.
Powell says that this is obsolete and that they can't do anything for me except add a section of CH and transistion from the existing to the new.
I was wonder if anybody out there had some recommendations for getting this done, we would like to have new buckets made, but are also open to rebuilding a couple of existing size 4 buckets if they are large enough.
Erik
Erik
RE: Retrofitting an old Powell 480V MCC starter.
I'm guessing it will be cheaper (eventually) just to buy new sections. Maybe get rid of the whole thing while you're at it.
Let me guess - a sawmill maybe?
Also, re-using the existing sections will likely require a longer outage than buying new.
You could throw in something about safety as well.
Besides, most likely they were not stab-in were they? The usual limit on that is Size 4. So if they were bolt-in, why not just replace the bad components with new ones anyway? In fact, a good argument could be made to replace those behemoths with solid state soft starters.
