8" x 3 km Flowline Intelligent Pigging
We just completed the IP of an 8" x 3km gas flowline that was installed in 1987. This line has an external bullet ponit defect measuring 16mm long x 11mm wide x 5mm deep at 3 O'clock position with the bultt in place and is a schedule 100 pipe with Nominal wall thickness of 15.1mm. The final IP report revealed no single defect on the line(neither external not internal) not withstanding that the bullet point has not been repaired. The IP tool in question is an MFL tool and auxillary pumping was empolyed using water as the fluid.
My questions are:
(1) Is it possible for a line to be in service for about 20 years without have a single metal loss defect?
(2) Is defects such as bullet point not detectable by MFL tool?
(3) What is the minimum defect size that an MFL tool can detect?
(4) What are the possible reasons why this defect was not detected?
My questions are:
RE: 8" x 3 km Flowline Intelligent Pigging
2. Not sure exactly what you mean when you say bullet point, but certainly a defect of that size and depth should have been easily detectible by the pig.
3. Depends on the tool specifications/vendor. I assume it is a high resolution MFL tool, these can detect corrosion defects even less than 10% and 1 cm size pits quite easily.
4. Possible reasons, was the line cleaned before the run? If it was not the tool will loose sensitivity if there are internal corrosion deposits (magnets loose contact). Was the run valid (was the tool working the entire time)? Did it loose power at any stage in the run? The wall thickness it quite thick for an 8", is the tool capable of magnetizing (saturating) this wall thickness at this diameter of pipe? The pig was calibrated correctly before hand. You might not want to state the name of the ILI vendor, but some are much better than others...
