Hydraflow Compute System Question
When using Hydraflow, you have an option to comute the system using "Full Design" which is supposed to design the system based on your design codes. If I have a minimum slope of 0.5% and a minimum cover of 4.0' specified in the design codes and use "Full Design", the result is the entire system is designed with a slope of 0.5%. The downstream end of a pipe segment looks ok for minimum cover but it uses 0.5% for the pipe slope and the upstream end of the pipe segment is too deep. Any ideas or is this the way it designs the systems.
RE: Hydraflow Compute System Question
good luck
