MDEA or Speciality Amines vs. Connvectional Amines ( Benfield Solution
mrobles1942 ( Petroleum)
An important client of us wants to replace the “Benfield Solution” by “MDEA” for CO2 removal in the purification section of his Hydrogen Plant.
The main reasons to carry out this change are:
1) MDEA consumes less energy in the regeneration (steam reboiling in the stripping column).
   ( “We must evaluate this  energy saving”)
2) MDEA works with more strength (concentration) and higher molar ratio between: (Acid gas / Amine).
Both facts means: “Energy benefits” (less amine recalculating flowrate) and “Hydraulic overcapacity” (in the System: Columns, Lines and Recirculation pump)
    ( “ We must evaluate both  benefits”)
3) MDEA is less corrosive
However, due to the MDEA reaction rate with CO2 is slower than   the other Amines ( MEA, DEA,..) to overcome  this  disadvantage, we think, it would be necessary to  increase  the number of the  theoretical stages in the absorption column to get the same degree of  hydrogen purity. ( “replacing the existing  random beds to the more efficient structured bed”)
 ( “We must evaluate this change of performance”)
We would appreciate very much any comment about the advantages and disadvantages in this Amines replacement.
Finally as I must recommend the amine type (MDEA or Speciality amine like aMDEA), we would be appreciated to inform us about the differences in chemical composition and behaviour between aMEDA ( or other speciality amine)  and MDEA
Thank you to all the colleagues
P.S. :
Benfield Solution composition:
        KCO3       30      wt%
        DEA        3-4      "
        V2O5       0.7      "
