Oxygen In Amine and Glycol
What would be an acceptable level of oxygen in the inlet to an amine plant and/or a refrigeration plant with EG dehydration and hydrate inhibitor.
I know that the oxygen will react unfavorably with the acids in the amines and glycols causing corrosion, however I have not found what is high or what is too high.
Should it be in ppm levels? ppb levels?
RE: Oxygen In Amine and Glycol
