Vehical Dimensions
Vehical Dimensions
Vehical Dimensions
I'm looking for vehicle datd for my turning program. I need the cab lengh, cab overhand, cab WB, distance form rear wheels to king pin/ hitch, if there is a trailer, lock to lock time, stearing angle, artiulating angle, cab width, cab WB width, trailer width, trailer WB width, trailer distance form kingpin/ hitch to center of wheel, overall trailer dimmension, and the distance from the front of the trailer to the kingpin/ hitch. If anyone could help me out on this information on alot of vehicles that would be helpful.
Thanks for the help
RE: Vehical Dimensions
The AASHTO Green Book has some of the info you need.
JonYoung,
AASHTO has "design" vehicles defined for structural load and (I assume) geometric design. You should use these unless there is a specific vehicle that you need to accomodate.
Jeff
