Hub centric rings
Hub centric rings
I am a mechanical engineer and a car enthusiast, but not an automotive engineer, so I am asking for some very technical advice:
I want to install aftermarket wheels on my car and I need to use hub-centric rings. I would like to know what are the standard tolerances on the hub OD/wheel ID and what kind of fit do I need for the rings?
Thank you
Thank you
RE: Hub centric rings
Your options are aluminum and plastic, people typically swear by one or the other. Plastic doesn't stick to the wheel or hub when swapping rims, so you can't (easily) put on a rim that has two rings. Personally, I like the aluminum because they do stick... means I don't have to wonder where the ring is, I know it's still in the wheel. A pair of rings for each rim set and you're good to go with every swap.
Dan - Owner
http://www.Hi-TecDesigns.com
I have had plastic. They fell out and got lost and ended up with 2 on one hub when careless tyre fitters did their thing.
The plastic ones also distorted with heat in my case.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
I'll go on ebay and order the rings.
