Breaker Time Current Curves
Does anyone have a good Internet resource for older breaker units,
Trying to find manuals, time/current curves, and any other information.
I have tried the manufactures website and they did not have anything,
It's for a Westinghouse breaker and I believe that Siemens now owns or at least bought out Westinghouse.
Jeff
RE: Breaker Time Current Curves
Westinghouse was bought by Eaton (Cutler Hammer), not Siemens. As far as I know, all of the curves for old breakers are available from them, but depending on how old you are talking about, may not be available on-line.
As jraef says, the Westinghouse low voltage and medium voltage lines were purchased by Cutler Hammer, (now Eaton) many years ago.  The old Westinghouse electromechanical protective relays are now made by ABB.
You will find some old curves on the Eaton website.  See here:
http://www.eaton.com/EatonCom/Markets/Electrical/Tools/TimeCurrentCurves/index.htm
They also provide a means on their website to send requests for technical information.  I've used that in the past to get curve data for old molded-case breakers.
For GE devices, you can always try here:
http://www.geindustrial.com/solutions/consultants/Time_curves.htm
They are hard to find. I have many curves for the type of breakers you are describing. What model trip unit do you need the curves for?
