significant figures
significant figures
Should significant figures apply to GD&T? What do you do when dividing decimals with different decimal places.
RE: significant figures
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
Want to post an image? Look at the FAQ's in forum559: SolidWorks 3D CAD products
Tolerances should not be held to significant figures, they should be held within the accuracy bounds which are needed. If you need three digit accuracy, and put only two digits, then the machinist will give you a part with two digit accuracy. Conversely, if you give him (or her) four digits then more time would be spent trying to hit the four digit accuracy within the given tolerances.
Back to the point. Give tolerances as needed, do not add an extra decimal because of mathematical operations.
Taking the science out of rocket science...One step at a time.
shoud the answer be 2 decimal places like the more precise dim'n ? or 1, or 3 ?
maybe you should express the math as 1.05/0.495 or 0.95/0.505 ... ie explore the limits of the dim'ns provided ??
To expound upon Mullins-
In the typical American (mechanical drawings) tolerancing system the number of decimal places corresponds to tolerance range given in the title block.
For instance 3dp may be +- .005, 2 dp may be +- .01 and 1 dp may be +- .03.
In other countries/working to other standards general tolerances like this are done differently.
When doing tolerance calculations I'll usually use all the decimals available and then round the result as required at the end based on function/title block tolerances.
KENAT, probably the least qualified checker you'll ever meet...
cmwatson78, any chance you can give a more detailed question.
