Require Cabin Interior 3D Modeling Services
Need to identify companies that provide airline cabin interior modeling and simulation services; ideally with stock models that can be easily edited to show before (typical) and after (custom) interiors.
Thanks and Best Regards,
1111
1111
RE: Require Cabin Interior 3D Modeling Services
Artisitc impressions, Design, Static analysis, dynamic analysis. By stock models i take it you mean 747, 737, A380 etc etc. If you do then you need to be aware that there are many variants of each generic aircraft type, and furthermore, each user (British Airways, virgin etc) has there own layouts which change on a route/seasonal/new image basis. The OEM's will give a general layout which is acceptable, and this includes changes that the airlines can make without re-evaluation of the airframe. The OEM's also provide specific tailored requirements (for a cost). Third party design organisations will design changes for you on a modification basis.
These models are on all of the manufacturer's web sites under "cabin interior illustrations and tours." You know... drag your mouse around the cabins for a virtual tour.
That's it. No FEA or structural analysis; just a computer substitute for building and filming physical prototype models and mock ups. (Frankly, I could do this myself with a good 3D illustration package but don't have time and it wouldn't look as 'real.')
Thanks for any info on companies providing airline cabin visualization modeling.
Best Regards,
1111
or try http://www.teague.com
Wes C.
No trees were killed in the sending of this message, but a large number of electrons were terribly inconvenienced.
http
