BH Curve of 1018
BH Curve of 1018
Looking for the BH curve of 1018 if it exists. Also, any other magnetic properties of this material.
Thanks!
Thanks!
RE: BH Curve of 1018
What other magnetic properties are you looking for?
Any thoughts?
Mike
Most 10XX series steels are not processed with magnetic properties in mind, so you're going to see a lot of variation.
One should only consider published BH curves as approximate (same goes for that supplied by your software). Going from 1008 to 1018 (assuming the heat treat and mechanical work is similar) is only going to cause 2 to 3% change in output.
