edit assembly report?
i want to print off a list of parts used in an assembly, and their quantities, but don't need the rest of the crap that comes with it.
Solid edge has an easy to use list function where you can specify what it will list and in what order, i can't find in the help where i can do this with NX3
RE: edit assembly report?
Anywya, that's your best bet since you will 100% control over the content and format of your data as well as what sort of file will you save the resutls in.
John R. Baker, P.E.
Product 'Evangelist'
UGS NX Product Line
SIEMENS PLM Software
Cypress, CA
http://www.siemens.com/ugs
Good Luck
Hudson
Best of Luck
Hudson
Right click in the white space and you can configure the columns you want and the order they appear. Then pack/unpack and collapse or expand the items as desired before exporting to spreadsheet or browser.
