Level Transmitter Calculations
I need to verify a level transmitter calibration. In order to do so I want to use the proper formula for determining the correct inwc. Assuming water what would be the correct equation to use?
RE: Level Transmitter Calculations
Erik
MO P.E.
example: measurment is 55.3" (w.c.) of something lighter than water at 0.91 S.G.
55.3/0.91 = 60.8" physical level
