Unfolded Section Views?
I am trying to do an unfolded section view in wildfire 3.0 but can't seem to figure out the right steps.
In the section dialogue box the "Full(Unfold)" is always greyed out. The help says that once you have a valid name for the section you'll be able to select this option and set up your view... but this doesn't happen. I can only produce a single plane section view.
What steps are required for making an unfolded section view?
Thanks in advance for the help.
-Andy
-Andy
RE: Unfolded Section Views?
