mirror hole wizrd features
How come when i mirror hole wizard features on my drawings it only displays half the amount?  I understand that the mirror is controling the other half but isn't solidworks "smart" enough to figure that out?  How do poeple deal with this issue in drawings is there a setting?
Currentyl I manualy overide the number in the hole call out but don't like that as it puts it in my hands to update the hole callout if there's a rev.
thanks.
Grant
Applications Engineer
SW2007 SP 3.0
IBM InteliStation Pro M
P4 3.4 GHz, 2GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 3000
RE: mirror hole wizrd features
I don't mirror hole wizard features.  I can usually get the same effect by mirroring the sketch points inside the locating sketch.
oghh mind blank there that makes more sense and i usually do that way!! It's a monday....
Grant
SW2007 SP 3.0
P4 3.4 GHz, 2GB RAM
XP Pro SP2.0
This is something that our company noticed quite a while ago. I may be wrong but I do believe it was classified as a limitation and I'm almost certain it was submitted as an ER, however I have yet to see it work.
Possible suggestion would be to either pattern the hole feature or as handleman pointed out locating the points in the sketch.
