Globe valve with indicator
I am wanting to use globe valves for throttling flow in a marine cooling system application instead of an orifice.
But once I adjust the globe valve to the proper position, I want to ensure it can be repositioned to this same height if it gets mistakenly turned. Or a lock to prevent rotation would be good.
Is there a globe valve out there with a lock or a scale on the stem that shows it's position?
Thanks.
Thanks.
RE: Globe valve with indicator
Keith Cress
rmw
You will probably find the most suitable solution by mounting a lockable manual gear with indicator on your valve.
Check for instance www.auma.com
I would in addition suggest a regulating (manual) valve.
Some regulating valves are already factory equipped, or can by equipped with indicator and lock at factory.
