dual dimensioning
dual dimensioning
dual dimensioning
Hello all
I would like to know if any of you, in detail drawing are using dual dimensioning, inches and metric, and if so how can I do this? I´m using proewf3;
I know I have to click the dim go on edit prop. and activate dual dimension, but this is not available its blocked, how can I make it active, all I need is the option on the .dtl file on the config drawing option,this is what I have as default "dual_dimensioning no"
Can anyone help me, please?
thank you
