Cathodic protection system for cooling water pumps
Dear Collegues,
I have to handle a repair of a big cooling water pump (flow rate 90.000 m3/h and pipe diameter 2600 mm)in an Asian Power Plant. We are faced to heavy crevice corrosion between the flanges and between screws, discs and the components after one year operation. The main cooling water pump has been deliverd in Duplex steel (1.4462) and the sea water meets asian standard (Temperature of sea water 5° up to 40°).
Because of the fast crevice corrosion at the Dupelx parts I think there should be an electrical circuit which has to be stop. A cathodic protection system has been not installed.
1. Do anybody have experiance (and examples) with cathodic protection systems for sea water cooling water pumps ?
2. Can a cathodic protection system avoid crevice corrosion on a Duplex pump ?
Thanks for your tips and reply.
If you want more details and photos of the crevice corrosion, don´t hesitate to contact me, please.
Greetings from Germany
Energypumpexpert
Energypumpexpert
RE: Cathodic protection system for cooling water pumps
Steve Jones
http://www.pdo.co.om/pdo/
S.
http://www.corrosionist.com
You may need to look at weld overlay of the flanges with a high Ni alloy to prevent crevice corrosion.
Still trying to help you stop corrosion.
formerly Trent Tube, now Plymouth Tube
eblessman@plymouth.com
or edstainless@earthlink.net
The company Force technology have developed a resistor controlled cathodic protection system (RCP) for handling such problems www.forcetechnology.com
Mekanikeren
