Power factor correction
The calculated capacitor to be needed to improve PF is 60kvar. But the closest standard size is 50Kvar. the next size is 75kvar. I am thniking of adding some heaters in the pump house to help improve the P.F. Is it workable solution? Is there any other alternative? We don't want to spend money on an automatic capacitor or a custom designed one, which is more expensive. I appreciate any inputs.
RE: Power factor correction
Keith Cress
Are you in North America and are you penalized for a power factor of less than 0.9 or are you in a country or area where the penalty is less forgiving?
What is the nature of your load? Do you have a few large motors, lots of small motors or a mix of motors.
How many hours a day does your plant operate? How many days a week does your plant operate? Is there different loading on different shifts?
What type of plant do you have?
Do you have your own transformers?
Do you have any motors that typically run 24 hours per day?
These are all questions that I consider before applying the "Art" of power factor correction.
The science of power factor correction often costs a little more than the art of PF correction, but not as much as fully automatic correction.
After assembling the data I first ask;
How many KVARHrs per month do I need for 100% correction?
How many KVARHrs per month do I need for 90% correction?
How Many KVARs may I safely connect 24/7 and how many do I still need?
How many large motors can I correct to 100% with permanently connected capacitors and how many KVARs do I still need?
Are there any motors that run 24/7 and how much capacity may I permanently connect to them?
If there are a large number of smaller motors, I will consider correcting them in groups. A PLC may monitor the motors and connect a capacitor bank with a contactor whenever there are enough motors running to absorb the KVARs.
If the motors typically run together on a machine, I would not use a PLC but just use auxiliary contacts on the motor starters to pull in the capacitor contactor when all of the motors are running.
There are a few other tricks to the "art" of power factor correction.
The first rule of the 'Art" is do not do more than required.
If your penalty starts at 90% then correct to 90%.
If you incur a small penalty one or two months out of the year after correction, step back and look at the numbers. You may decide not to spend a few thousand dollars on added correction to save $30 or $50 a year in penalties.
If you care to provide some numbers and a description of your plant, we may make more specific suggestions.
respectfully
Question: Why not?
respectfully
Most local utilities pass this along to their customers.
rmw
I think that Smoked has a very valid point.
If difference between 50 and 60 kvar compensation is important, then the total load seems to be 1. very small, 2. very constant throughout day, week and year and 3. has a constant PF.
Most automatic (switched) compensation equipment have larger steps than 10 or 15 kvar. But it surely is possible to build equipment with smaller steps. Using one fixed compensation is a mistake. It is very difficult to imagine a load that is constant in both power and reactive power, as described above. Unless it is a process plant running an identical process for years.
Hamid: What is your power consumption (low/high) and power factor (also low/high) over the year?
Gunnar Englund
www.gke.org
The required Kvar is 55kVar-65kvar to achieve power factor of 0.90-0.995. If we use 50Kvar capacitor, the Power factor is below 0.90. If we use 75 Kvar, the power factor will be leading.
Skogsgurra, maybe use a fixed capacitors with small steps, like 10-15kvars.
Surprises me greatly.
Is this your 5MVA transformer?
Does the utility have a meter on the 15kVA side?
Are you doing this because of utility charges/penalties?
Keith Cress
your current power factor - k1
power factor you need - k2 (0.9)
Q=P*|{tg[arc(cosk1)] - tg[arc(cosk2)]}|
So recalculate like david said, because if you need 65Kvar for 15KV that means you have power factor around 0.2 now, and I don't know with what could you do that because it is almost pure inductive load. Must remind you that most of the engines have cosf around 0.8
I think that you should: A) either stop worrying or B) talk to someone that can explain this to you or C) dig out your text-books.
Gunnar Englund
www.gke.org
Almost all of you charge is for energizing an unloaded transformer. IF the utility would agree, you might check into using a single phase 13.2 kv 25 kva transformer for
small load and disconnect the 5000 kva transformer or move it to where it can be used more efficiently.
If it is, I believe that smaller transformer station would show as a cost effective solution. Remember that beside your load power spent you should pay for currents of magnetization and power factor correction equipment for some 120 - 160 KVar the cost of such capacitors (and what if you need to connect more p. load and rectify power factor for that also in future) and that might show up as a costly long time solution. If I was your boss we would have serious talk about engineering principles in planing and projecting.
What you should know is:
1. Who is the owner of that transformer (why would you pay for power company reactive power loses)
2. What is your load.
3. What is your expected load in near future
In case you have big transformer in your property you should consider selling it and buying transformer of smaller power, I believe that counting on current cost of transformers you would not lose anything in its initial cost. Buy small power transformer that will cover your near future consumption, and consider purchasing one more in future that is able to work in parallel operation with this one. Create long term development project that would include more transformer fields with or without parallel operation. If you don't do that your costs will rise over time and costs for buying new capacitor banks for rectifying power factor before transformer load reaches over 70% will be so costly that my boss would fire the person that suggested buying such big transformer at first (5 days ago he wanted to cut from my salary difference between p-factor correction from 0.87 to 0.95 instead 0.93, I was calculating because junior engineer gave me wrong data and it was just talk and no capacitor banks were ordered).
I understand that the problem is the customer! aha! Why does the customer disagree taking out the 5MVA loaded at 1% of its rating! You don't have to worry about penalties if your transformer is sized to your needs - and that's the solution. You don't get charged for low PF, you don't have to buy capacitors, and most of all, your voltages don't spike!
Convince the customer to just de-activate the 5MVA, don't pull it out but install a 50kVA, 25kV primary(if line-line, or 13.8 kV if line-neutral loading).
My two cents!
In this case I would suggest adding enough capacity between the 5MVA xfrmr and the 50KVA xfrmr to equal the exciting KVARs of both transformers.
Don't correct to unity, just correct enough to eliminate the penalty charges. If standard sizes don't get you in the window, calculate the penalties payable for the smaller size and contact the utility for their policy on slightly leading power factors.
Then decide what size to go with.
respectfully
