HDPE Transitions
HDPE Transitions
I'm laying out the gathering system for a new field development, the client likes SDR-7 HDPE and I've modeled the trunks, laterals, and individual well flow lines and have settled on 10-inch SDR-7 on all the trunks, 6-inch SDR-7 on the laterals, and the well flow-lines are 4-inch SDR-7.
The pressure drops and velocities all make good sense, but now I'm looking at how to tie the pipes together. My first look said that I didn't want a bunch of weight stacked above a plastic pipe so I was going to transition to steel a joint either side the tie-in risers. As I read about this stuff I'm thinking that maybe I'm being excessively conservative. If I use a 10X6 reducing tee in SDR-7, transition to steel and immediately swedge down to 4-inch S-40 steel for 3 ft, and then set about 700 lbs of valves, fittings, piping, and flanges on top of it will I break the 10-inch? If it is a problem, I can come off with the tee on the horizontal and 90 up with a thrust block under the 90, but I wanted to avoid the potential water trap.
David
David
RE: HDPE Transitions
http://virtualpipeline.spaces.msn.com
I'm trying to determine the "best" way to connect the flow lines to the laterals and the laterals to the trunks.
David
WWW->WWWWWLWWW<-WWW
WWW->WWWLWWW<-WWWWW L
L L
L LWWW<-WWW
L L
L L
TTTTTTTTTTTTTTTTT->TTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTT Comp
L
L
WWW->WWWLWWW<-WWW
The "W" are 4-inch SDR-7 well ties, the "L" are 6-inch laterals, and the "T" are 10-inch trunks.
David
Is it save to assume that the 10X6 reducing tee has been reinforced to allow the 10-inch leg to resist buckling when the branch is a max load?
David
I would put some flexibility into the tie-ins and the laterals as they approach the laterals and trunklines, respectively, to avoid large axial loads from dumping into the connection. I think large axial loads from the lateral would tend to displace the 10" first, rather than buckle the T. There will probably be some thermal movements and I think allowing for those movements might be good, as it will aleviate any punching and bending into the 10", so I
don't think I would use thrust blocks either.
Actually I'd just do it like this and not look back.
use valve pads or sand-cement bags under the valves and their fittings.
I've decided to transition to steel about 1/2 joint either side of the tee for the valve set and then all the problems just vanish and I can build my valve sets the way they need to be.
Thanks for looking into this.
David
