Cooling capacity using water vs. 60/40 EGW
Does anybody know how to quantify the performance difference when using 60/40 egw instead of water in a chiller evaporator that uses R134a refrigerant?
RE: Cooling capacity using water vs. 60/40 EGW
How cold are you going?
The mix should only have enough EG to keep the fluid from slushing, otherwise, you're simply wasting refrigerant capacity.
TTFN
http://download.yousendit.com/E2949E9B4191B7C0
Glycol systems are usually slightly more expensive than water systems. There is a one-time initial cost to fill the system with 30-40% glycol.
Convenience - In cooling systems where components are frequently disconnected and reconnected, the glycol is typically captured and added back to the system
TTFN
