Surface Finish Help
Surface Finish Help
Surface Finish Help
I am reviewing a print in which the surface finish is called out with a check mark like normal; however above the check mark is 18Z.  I need to know what the "Z" stands for.  Is this a unit of measure, similiar to micro-inch/micro-meter or a parameter similiar to Ra?  I can tell you that I found this on a Japanese automotive print if that helps.
jeremy
RE: Surface Finish Help
Is this a CAD drawing?  It may actually be a typo of some sort.
Matt
CAD Engineer/ECN Analyst
Silicon Valley, CA
sw.fcsuper.com
Co-moderator of Solidworks Yahoo! Group
