User Defined Feature Library Icon/Name Removal.
We are running NX3 Native on Dell PCs and I have recently created some UDFs. In my learning process I created some that were not as intended so I deleted the .cgm and .prt files from the proper folder. My question is, these deleted names still appear in my Library window so how do I clean it up. Also I would like to reuse these same names for future UDFs and since thay appear in this Library window the system tells me they are in use.
Gary Ashby
Designer
RE: User Defined Feature Library Icon/Name Removal.
Message - Invalid entry found. Please check the part and cgm files.
This message appears after I select the desired UDF from the Library window. The picture displays in the Library window so the .cgm file must me valid. This leaves the part file as questionable, but I can not figure out why. I can open the part file in NX from where it resides in the /resource folder, and the udf_database.txt line looks like this:
Insert_NAS1130-08L20D;$UGII_ROOT_DIR/udf/resource/Ingenium/Insert_NAS1130-08L20D.prt;$UGII_ROOT_DIR/udf/resource/Ingenium/Insert_NAS1130-08L20D.cgm;/Ingenium;;
Thanks again for your help.
Gary Ashby
Designer
Thanks all for you help.
Gary Ashby
Designer
You should be able to edit the TXT file you refer to, cleaing out any "old" data.
Specialty Engineered Automation (SEA)
http://www.sea4ug.com
a UGS Foundation Partner
Gary Ashby
Designer
C:\Program Files\UGS\NX 3.0\UGII\library_dir.txt
I deleted the unwanted names out of this file and now our "No Library" menu appears minus the names we did not want.
Gary Ashby
Designer
