SW08 Desktop Engineering review
http://ww w.deskeng. com/ME2/Si tes/dirmod .asp?sid=& amp;nm=&am p;type=Pub lishing&am p;mod=Publ ications%3 A%3AArticl e&mid= 8F3A702742 1841978F18 BE895F87F7 91&tie r=4&id =4E3E1A47B E6D47ED9B5 A57FEE206F 633&Si teID=D90B8 FD2293D42F 09CD46C33C FA3EF4A&am p;AudID=2F C31F0C0A2E 42978C555C 9CA2D3F0EA
I have not read it all yet, but thought i would share this with those that have not seen SW08 yet.
Scott Baugh, CSWP ![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
"If it's not broke, Don't fix it!"
RE: SW08 Desktop Engineering review
Hey, has anyone been playing with '08 Beta? I finally got around to submitting an ER for an issue that's been annoying me for a while, but after reading this article I thought I'd ask if anyone knew if it had already been implemented:
I hate that you have to create your hole location sketch inside the hole wizard. The main reason is that you can't run macros while the wizard is active. Other features let you create the sketch (or sketches) and then click on the command button. Does '08 let you create a sketch with hole location points before running the hole wizard?
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
http://urltea.com/
Nice tool to use here or elsewhere.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
Rodrigo
www.morrisonpump.com
