Pull-Out Force (lbs) in 6061 T6?
I am a New member to eng-tips.com and would appreciate your help in determining pull-out lbs for the specifications below.
I spent the past week trying to find a good formula / calculator for Pull-out force in aluminum with a SS bolt.
My Situation:  1/4-20 SS fastener in 6061 T6 Aluminum.  Recommended Engagement .612"
I am able to calculate Internal and External Shear Areas for Threads and Minimum Thread Engagement; however, I am unable to calculate Pull-Out in lbs.
One formula I came across:
  Pnot = 0.85 (Te)(D)(Ftu2)
  Te = length of thread engagement
  D = nominal screw diameter
  Ftu2 = tensile ultimate strength
  3124 = .85 (.612741) (.250) (24,000psi)
3124 seems way too high of a number for a 1/4-20 in .61" aluminum...
Am I missing something?
Jim
