NX4 Plotting .gl2 files
Need help; does anyone know the steps to making plots into .gl2 file format? Thanks for the help.
RE: NX4 Plotting .gl2 files
I'm assuming a gl2 is really just an hpgl file. First you need an appropriate printer driver installed. Check HP's website for hpgl printer drivers. You can then either select the driver through the print option, or if you know how, configure a printer through the printer administrator so you can get to it thru the plot menu.
