Center of gravity
Center of gravity
I need to find out if there are some guidelines available out there on calculating center of gravity on gas panel/box (VMB). I appreciate all the help you can give me.
RE: Center of gravity
modern CAD and CAE programs have the capability to calculate center of gravity of any given geometry, if you have both of possibilities then choose the one from CAD, since this is more precisely concerning the discretization failure.
cheers,
ichwan
cg of the area can be found manualy or cad/cae
s/w as rightly said by my friend zuardy.if you want
to cross check you can do by known analytical
method available in some std. strength of materials
related subject.
cheers.
