can hole wizard parameters change per config?
Hi there -- is it possible to alter any of the hole wizard "Type" settings per config? I was hoping to fill out a design table with different NPT diams and have the wizard feature generate the NPT geometry, but seems like the hole wizard doesn't want to put itself into the design table, and for that matter it can't even be changed manually between configs... I'm wondering if I'll have to just do it with a regular cut.
I'm also wondering if there's a list of all the generic parameter names for each feature, like D1 in an extrude is the extrustion distance, D2 in a pattern does what, etc... anyone know?
Thanks for any input!
RE: can hole wizard parameters change per config?
Second question: I've never seen a list of that sort. If you did try to make one I wouldn't be extremely confident about its consistency either. It's too easy to change the name of a dimension.
Q2 ... Dimension parameters/names are alloted sequentially as features are created. I don't believe a preference exists for feature elements.
I was initially confused by your second answer, but then I played around and discovered how to rename the parameter (e.g. D1, D2) for those features... had I of known that before posting I probably wouldn't have asked Q2 :) so I'm clear now.
Thanks guys!
That way, when they are populated into a DT or an equation, it will be much easier to understand.
