Flashing losses in refineries
Dear all,
I am preparing an initial report describing the emissions due to storage tanks (crude, intermediate products, final products) in refineries. I am considering working and standing losses and I am looking for information about flashing losses but everything I find regards to Exploration and Production (not refining). Are those losses usually negligible in refineries or must be considered in some situations? Any information?
Thank you.
Thank you.
RE: Flashing losses in refineries
In order to determine a number you need to evaluate each vessel or at least type of vessel and determine the vent system it has. The type of vent will greatly influence the amount to atmosphere. For instance a vacuum tank should have no emissions from breathing whereas a tank open to atmosphere would lose whatever evaporated from the liquid.
Sorry no easy way out.
Are you aware of the publication by the U.S.A. Environmental Protection Agency (U.S.A. EPA) known as "AP 42, Compilation of Air Pollutant Emission Factors"? Chapter 7 of Volume 1 of that publication is entitled "Liquid Storage Tanks" and includes the methods for calculating the vapor emissions from all types of tanks. The U.S.A. EPA also makes available a downloadable software program called "Tanks" which does the calculations for you.
Read this Wikipedia article to learn more:
http://en.
The "References" section of the above article has links to the online AP 42 publication as well as to the Tanks program.
Milton Beychok
(Visit me at www.air-dispersion.com)
www.de
Do they happen at refineries?
Air emissions from refineries are regulated by the EPA and much work has been done over the years to limit the emissions to the environment. There are not any uncontrolled flashing emissions. Emissions are typically vented to an air pollution control system that greatly reduce the amount of material discharged to the environment. The materials captured by the air pollution control system may be recycled back to the process.
Here is another source of information:
http://www.socma.com/Issues/issues/air.htm
There are dozens and dozens of closed systems in a refinery wherein a saturated liquid is reduced in pressure and which then results in partial evaporation (called "flashing") of the liquid. But such operations are all in closed systems and are part of a process operation. There are no "losses" or emissions from such closed systems.
Flashing does not occur in storage tanks unless a liquid stored at high pressure accidentally escapes into the ambient atmosphere through a leak. For example, if an LPG tank or a liqufied ammonia tank or a liquified chlorine tank has a leak. But that isn't a normal operational emission ... it is an accidental release.
If you want to learn more, read this article:
http://en.wikipedia.org/wiki/Flash_evaporation
Milton Beychok
In a refinery we do not intentionally have any flashing losses. You have restricted your question to storage tanks so I think you need only estimate breathing and working losses from storage tanks. Flashing from refinery storage tanks can be assumed to be neglibible.
HAZOP at www.curryhydrocarbons.ca
Instead, I use the BV method to estimate flashing for both air permitting and for annual SARA Tier I/II reporting (and we have California AB2588 reporting requirements to meet as well).
